Thank you for your feedbacks. First OS X version in attachment.
updatedMiddleButton_1_5_4R6.zip (19.4 KB)
lifesaver!! thank you very much!!
Thanks for the mac version !
Hi Denvi,
This plugin is really useful to me.
However, I experience the same issue encountered by ancomic:
So, using the debug version available (MiddleButton_1_4_4R6_DEBUG.zip), I took some logs.
If these are not enough, I will be happy to perform any tests on your request.
Thank you very much.
Debug_logs.zip (996 Bytes)Debug_logs.zip (996 Bytes)
Hi, chatraed. Please post your configuration files: āsettings.zvrā, ācustom.zvrā from āZStartup\Zplugs\MiddleButtonā folder.
Check if the zb function: āPreferences - Interface - Navigation - RightClick Navigationā is enabled when zb was launched with activated plugin.
āā¦nothing worksā¦ā - includes zoom with scroll wheel?
Thanks.
Hi Denvi,
Your feedback is much appreciated.
Thanks for your help!zvr_files.zip (342 Bytes)
Hi, chatraed.
Please install plug from attachment, start ZB, enable plug and post error number from message box (it will have the following form: āError installing hook: xxxxā) if it will be shown.
This is intended behavior.
Thanks.MiddleButton_1_4_4R6_HOOK.zip (12.6 KB)
Good day!
Would you please guide me how to perform this step: āenable plug and post error number from message boxā.
If I simply uninstall all previous version of plugins and install the ā_HOOKā version, then enable/disable it upon the ZB start/restart, no error pops up.
then start ZB, set āEnableā in plug, restart ZB. If there is no error, Iāll look for another solution.
We continue our investigation.
Reinstall plug with attachment one. Start ZB. Look to upper right corner of your screen. There should appear the numbers like on the following picture:
What numbers do your have?MiddleButton_1_4_4R6_MSG.zip (13.1 KB)
Using MiddleButton_1_4_4R6_MSG.zip, every time there is a different number. Examples attached:
After restarting ZB with plug enabled first 2 numbers are equal? 3 & 4 numbers = 0 and plug does not work?
Previous numbers were all taken with plugin disabled at ZB start up.
Here are some numbers with plugin enabled when ZB starts:
Plugin isnāt working in this case.
Thanks.
Hi Denvi,
It seems to be working now!
However, there is still a corner case:
Way to reproduce:
Itās not that severe issue and I could live with it.
But if it is easy to solve, it would be great.
Thanks.
Thanks a lot, if I could I would kiss you for this :D;)
I have Macintosh (MacBook Pro) not PC. Where can I put plugins for Zbrush on MiddleMouse?
mac4kent > ZBrushās plugin folder is :
Windows > āC:\Program Files (x86)\Pixologic\ZBrush 4R?\ZStartup\ZPlugsā
Mac OSx > ā/Applications/ZBrushOSX 4R?/ZStartup/ZPlugsā
Denvi > Just wanted to say hi and thank you again for the help on ZAdjustor
Hi to you back Denvi smile friendly.
I got you thank you for show me direct on Mac Application > ZBrushOSX 4R6 > ZStartup > ZPlugs > ā¦ on Youtube show you.
Problem I did show you on youtube there is error open Zbrush on MiddleMouse.
