So I’ve been sculpting models for 3D printing as tabletop miniatures, and have decided to try my hand at using Micromesh as a means to make maille, scales, etcetera. However, when I try to do so, it ends up getting HUGE seams and open holes on the borders of where the polygons were. The attached image shows the problem (and yes, I know it’s overlarge, the intent is to be printed on a resin printer at about 28 - 32mm to eye high, which is why it’s also not actual rings).
Is there any way for these patches to actually be welded to each other, or am I just that close to a workable solution only to fail?
