How to make Metal Railway in Substance Designer
Continuing the designer training series, we want to create a Metal Railway with pebbles for this episode. You will learn how to combine height data from different surfaces and control them to reach complex material. So, in this video, we will show you how to achieve this result in the substance designer and enjoy creating these types of materials in substance designer!
More Info:
https://www.artstation.com/a/16017894
Contents:
- 170 minutes of unnarrated videos
- 1080 Resolution
Chapters:
Chapter 01- First Step: In this Chapter, we start our process with the wood planks and block out our structure. And after that, we are going to add rails and metal connections to the wood planks. The next step is creating ground. For this material, we decide to have pebbles.
Chapter 02- Second Step: Continuation of the previous part, we start our work on the color, use the gradient nodes for the color sampling, and blend them to reach good results. And after creating our roughness data, we will add more details in color and prepare metallic channel data.
Software Used:
Substance Designer
Level:
Intermediate
Prerequisite Basic knowledge of Substance Designer
Attention: clean SBS file is included in this product that you can study over that (version of the designer should be 11.3 or above)
Attention: all videos are unnarrated (it means there are no voice-over videos or subtitles)
Do you want it ?
The other products too:
Broken Roof Tiles Tutorial - VOL 07:
https://www.artstation.com/a/15815559
Metal Retaining Wall Tutorial - VOL 06 :
https://www.artstation.com/a/15570800
STYLIZED PAVEMENT WITH MOSS Tutorial - VOL 05 :
https://www.artstation.com/a/15406536
Stylized Plaster Wall Tutorial - VOL 04:
https://www.artstation.com/a/15331498
Handmade Mosaic Tutorial - VOL 03:
https://www.artstation.com/a/15064540
Broken Tiles Tutorial - VOL 01:
https://www.artstation.com/a/14922290
Damaged Concrete Tutorial VOL-02:
https://www.artstation.com/a/14950781
Facade In Substance Designer Tutorial:
https://www.artstation.com/a/5308958
And other Products:
https://www.artstation.com/a/616780
