** RESOLVED ** Leaving this here in case anyone else has similar problem.
Loving QModeler and decided to assign the ‘Dynamic Subdivision’ command to a simple on-off click of the letter Z. No problem. Worked fine until it came time to use Spotlight. Now I can turn Spotlight on and off no worries, but to get the radial palette up you normally hit the Z button, right? Well, of course, now that does nothing except turn the Dynamic Subdivision on and off.
I have looked through the documentation and there seems no simple way of “undoing” that hotkey assigment. The Hotkeys/Restore option in Preferences is greyed out. The startuphotkeys.txt file is of no use either. See last line below:
//ZBrush Hotkeys
[BRUSH:MORE ITEMS,98] // B
[BRUSH:STANDARD,5447796] // Popup+T
[BRUSH:SMOOTH STRONGER,5447795] // Popup+S
[BRUSH:MOVE ELASTIC,5054565] // Popup+E
[BRUSH:MPOLISH,7151728] // Popup+P
[BRUSH:CLIPCURVE,4399203] // Popup+C
[BRUSH:CLAYLINE,4399212] // Popup+L
[TOOL:GEOMETRY:S.DYNAMIC,122] // Z
If I change that Z to another letter the Z key still turns on/off Dynamic Subd. (Yes, I saved and then restarted ZB)
The documentation for restoring factory default hotkeys is less than ideal. I am very wary of copying the example of the txt file in the doc’s since who knows how old that is and what I would do to my install.
I can’t even assign another key for the Z in Spotlight since that is the only way I know of activating it.
Anyone got any suggestions?
Resolution: I ended up copying my default hotkeys file as a backup then copied the text from online doc’s into it and saved. Restarted ZB and all back to normal.
This is what was in the doc’s
//ZBrush Hotkeys
[ZPLUGIN:MISC UTILITIES :<<BRUSH,219] // [
[ZPLUGIN:MISC UTILITIES :BRUSH>>,221] // ]
