I have an issue i dont remember the solution for. Basically i want to merge 3d text onto a mesh and i have tried to use dynamesh but the text is not high res when merged.
I’ve tried merging the subtools into one and using the same polygroups. Also tried setting high resolution before using dynamesh but the same bad result is showing.
What workflow do i use to be able make the text high res but also being merged to the main mesh
