Menu transparency ?
I find the transparency in the dropdowns menus in Zbrush to be too much, which can make the text hard to read, i.e. the ctrl+hover a function help
Is there a way to adjust or remove the transparency ?, I have been digging in the preferences, but cant seems to find it.
Best regards,
To adjust the opacity of the drop-down menus, change the Popup Opacity slider in the Preferences>Icolors sub-palette (the slider is about half-way down).
To adjust the opacity of the pop-up info which you get when holding cursor over an item or holding Ctrl, change the Quick Info Opacity in the same sub-palette (a bit further down).
It can be tricky. Been working on a UI here for about 3 years. Feel free if you’re able to try it.
Thanks a lot… Been struggling with that :smiley:
