MEL script for GoZ Button on the Maya shelf
After installing GoZ and following the accompanying video tutorial I pressed the GoZ button and it launched Maya 2011, created a new shelf entitled GoZ, but the routine failed to install the GoZ button on the Maya shelf.
Can someone publish the MEL script for the button so that I can create my own button and assign the script to it, if that’s even possible?
TIA
Never mind, I found the MEL script inside the Pixologic folder that was installed in the Shared folder by ZBrush, located at:
/Users/Shared/Pixologic/GoZBrush/Scripts/Maya/GoZBrushFromMaya.mel
It’s great you got it working. I downloaded the GoZ file but can’t seem to figure out how to install it. Any help would be appreciated.
Thanks
For me to get goz working in maya, I had to create this mel on a different or new shelf, other than the goz=
string $command = “source “C:/Users/Public/Pixologic/GoZApps/Maya/GoZbrushFromMaya.mel” ;” ;
eval $command ;
You could also try just sourcing GoZbrushFromMaya.mel in your script editor as a test to see if this shelf will work.
Goodluck
<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
Thanks. Will give it a go… rather a goZ.
I am working with Zbrush 4 and Autodesk Maya 2011,when I installed Zbrush 4 I
have a map named users with two maps inside ,one public and the other my name ,when I open the Pubic map ,I see a map Pixologic ,go inside there are three maps : first GoZbrush,second GoZApps and GoZProjects ,are these map on the right place ? Must they not installed inside Maya or Zbrush 4?
Who can help me with this problem
Thank you in advance
Stefan Kempeneers
[email protected]
Belgium
