Matcap material baked into texture map?
Hey guys, I’ve come up with a dilemma that hopefully someone can help me out.
Heres what I want to do. Is it possible to show the Matcap material baked into the texture map once you assign “New from, Polypaint”?
Im painting a skin color onto my character, and I used the RS_Skin Base Matcap material as the base (which is a great color) for painting the skin. However, when I paint the details and variations of the skin and assign the Polypaint texture to the texture map, I can only see the Polypaint information on my texture map. Hence the Matcap is not baked on the texture map, is there a way to do this?
I unwrapped a character from Max and brought the body into Zbrush to paint the skin. so there is no problem with the unwrap…only the matcap information…
Hopefully I have explained what I am trying to do properly, so if anyone has done this and can help me out, that’ll be GREAT!
Thanks
You can bake your material and shading info to your texture. Here a two tutorials that show different methods:
http://www.3dm3.com/tutorials/zbrush/baking/
http://www.youtube.com/watch?v=z6Bhrk-7rpM
Thank you! That second video really helped
finally! found what i look for! Thank KitchenDon.
