I’m having a weird issue with masking.
When using the mask pen, the mask will only draw at a very low opacity . When I hold ctrl + alt and draw it draws a stronger mask instead of erasing the mask. The same happens with all the other mask brushes (drag rectangle etc). If I use mask by cavity or anything else from the masking menu, the mask works fine.
This is only happening on one of my subtools, if I draw masks on the other subtools in my project, it works fine. Therefore I’m guessing it’s an issue with the subtool, and not the actual masking brush.
Is anyone able to point out what’s gone wrong? I’ve possibly hit a button accidentally turned something on I shouldn’t have, but I have no idea what.
