Does anyone know if there is a Mask Front option in zbrush? I am looking for a single button solution, something similar to the Group Front button in the Polygroups menu. Let me know, thanks!
I don’t think there’s an actual masking command but if you don’t mind the polygroups being changed you could have a macro that does it. This uses the Group Front command so the options for that will affect the result. Also, because there’s no zscript command for clicking on a polygroup the macro uses a “brute force” approach, so with certain models it might take a few moments!
HTH,
Thank you very much for the response Marcus and for taking the time to do the script. Very much appreciated!
