Hello. When I use the mask curve pen, how do I erase the guide line left over afterwardss?
Hello @Lupus ,
Live curves can be deleted by clicking with the curve brush on any part of the mesh that is far enough away from the live curve that it does not activate Curve Edit mode.
So for the masking brush, you would first have to hold down Ctrl to activate the brush, then click on any part of the mesh that is far enough away from the live curve that the cursor is yellow. If the cursor is cyan that means it is too close to the curve and is instead activating Curve Edit mode to modify the existing curve.
Likewise, you could use Stroke> Curve> Curve Functions> Delete Curve.
Thanks Spyndel. That really helps.
