Maps all outta whack: normal, ambient occlusion, displacement, etc.
Anyone else having issues with map generation? Mine don’t come out right at all. Thx
Stuff like that is usually the result of bad UV’s. ZBrush doesn’t like any of the UV islands touching the borders of the UV space. Just Move or scale the islands in from the borders a bit and it should be OK. You can check your UV maps by going to “Tool > Texture Map > Create > New From UV Check”. If there is any red in the resulting map, then your UV’s are bad. HTH.
…so I’m guessing my UV’s are totally screwed. I’ll have to investigate this further…Thanks for the tip.
