Like I said, quite a few :eek: :
Is there any way of using [Note…] or multiple instances of it, to point out several controls all at the same time?
Is there any way of taking a screen grab of an annotated screen, and putting it into a specific file?
When I use ‘Note’ to indicate Transform:Edit, it shows the one on the shelf, if that control exists on the shelf (as it does in the default configuration). When I use ‘IShow’, it shows the one in the Transform Palette. Is there a way for Note to show both?
Also, using IShow to show this doesn’t actually work (at least not when the Edit button is grayed out.) In fact, the cursor behaves a bit loopily, going off to one side of the Transform menu before going to it, and then it points a bit away from the ‘Edit’ control.
Pressing either of the left or right divider bars both result in a recorded command [IPress DIVIDER]. It plays back correctly, but I don’t know how. How can I differentiate between left and right?
Is there any public information on writing C plugins for ZBrush? Basically, just some C code that can talk to ZBrush using memory blocks and standard ZScript commands. (I would imagine that something like Projection Master is built in this way.)
That’s all for now
Thanks.
Ken
