I’ve been working on a project in which I have several tentacles to draw. I’ve been experimenting with several techniques. The technique I am sharing with you here is the one I have decided to use. This is a very basic tentacle. It should give you an insight on where to go with it. A note about the suction cups: I found that the mesh doesn’t respond well after such extreme distortion even when dividing and smoothing so I make/stretch the tentacle the way I want it then I create suction cups/hooks seperately and mult-marker them in. It gives much better detail that way. If anyone has any suggestions or their own techniques please post them. Thanks!
Here is the script:
Basic Tentacle modified.txt
