"Magic number" from ZBrush to renderman - 16bit
We are trying to find the “magic number” that informs a Slim displacement node how to mirror the results obtained in ZBrush with 16 bit displacement maps,
We were working with dividing the Alpha Depth Factor by 40 and pluging it into the displacement Kb. This works sometimes for a certain sizes of objects, but does not seems to be universal.
Any tips? formulas? help?
Many thanks in advance,
Richard
Animation Lab
I used 32bits displacement maps from Zbrush (and from displacement exporter 3)and from 3D coat without any problem. It wasen’t rendered in Renderman but in 3Delight.
Did you have texted this option ?
Thanks for your answer, we need to use 16 bit maps. I know that 32 bit maps work better but they are too heavy for the project we are working on.
Well, if the Alpha depth factor dosen’t work, maybe you could output 32 bits displacement maps, using the Displacement exporter 3, then use 3d coatto convert them to 16 bits displacement maps. (3Dc will give u a scale factor you will have to apply in renderman)
