I made a MACRO and then saved in both in Zdocs and Zscripts. However, I can’t find the button for the new Macro in the Macro drop down menu. I saved it as a .txt file. I am running Zbrosh 4R6 on a Macbook pro
Yes, you need to save the macro to a subfolder of the ZStartup\Macros folder. Probably simplest to save it in ZStartup\Macros\Misc. That way ZBrush will be able to find it when you restart or press Macro>Reload All Macros.
Yes, this worked and I can see it in the Macros tab now.
THanks!!
