Not sure if this is intentional or not (or if only I get this bug):
- Draw a transpose line on a subtool.
- Switch to ZProject Brush.
- Switch back to transpose.
- Transpose line is moved somewhere off screen or just disappears (also screws up your view rotation pivot point which is relative to the transpose usually).
This doesn’t happen with the gizmo, only the transpose line. I’d like it fixed just because I use the transpose line for precise view alignment (which is often needed when zprojecting).
Thanks!
