lost the EDIT MODE ... please help
HI
i have a small problem here
i am new at zbrush … (3 month using)
and I import the object, and use edit MODE to use some brush
but some times I lost the edit mode, and can not return to edit mode to use more brushes
how can I return to edit mode with out export model then quit and re-open again the app and import the same object again ?
any help will apreciate so much
Why are you still using 4R6? Upgrade to 4R7 and see if the problem still persists.
http://www.zbrushcentral.com/showthread.php?192994-ZBrush-4R7-P3-is-Now-Available&p=1134754&viewfull=1#post1134754
I just saw your other post and replied to it. The answer can be found there, but you should still upgrade to 4R7 anyway.
