Not happy because my activation hocus pocus is solved but jes knowing that others are experiencing the same problem is an awesome relief.
( misery loves company )
I was not really familiar enough with ZBC and at first glance it appeared that no one else was reporting the same behavior.
I originally activated after a slight hiccup 2 days ago thinking I needed to install version 4R2b to be able to install 4R3 today.
But when I fired up 4R2b this morning to deactivate it. Zbrush was acting like it was never activated.
Till now all Zbrush activations have always been very straight forward.
I definitely was not expecting my activation to dissapear.
I finally got 4R2b to activate again. To be sure…
I once again did a little sculpting with standard and fiber mesh.
Satisfied, I deactivated thinking 4R2b would update and activate fine now. But everytime I entered the activation code I got a message proclaiming that “activation was successful!” Hurray! right?
But after 3 to 7 seconds the activation prompt window, would start the process all over again!
Frustrating agony, much misery and gnashing of the teeth.
And then I got the message telling me I had no more activations. ( HUH?! I never presumed that failed activations would be registered as seperate activations! )
But every time I would fill the web form out…
If the description I gave differed at all, then another computer was added till the limit message exception was thrown.
Seems to me, that as much could be easily avoided if the webform used a dropdown menu list whose number of fields matched the same number of systems allowed.
( Instead of a single field without any reference to what may already exist )
Thankfully, The documents easily led me to the ticket system.
I am wondering if at one point if I did not use the right click “open as administrator” method to openup Zbrush for activation…
If that might somehow corrupt future attempts at activation even if following up with the right contextual choice?
At this point I can not recall if that was the case in my first attempt?
