Hi how is every one
Dose any on know why when I import s tool and then dynamesh then divide it up to 1.5mil ± ploys the mesh is good but it looks mottled as if parts of it is masked you can zadd to the mesh but you can’t zsub say with sk standard brush if you inflate you can z sub on that… so is there any way to turn it off or use zsub.
Thanks
Dan
Masking, clear mask.
Holding Alt while sculpting should perform the opposite function. Check that Mrgb or Rgb isn’t accidenly on, as that can ‘appear later’ in the process and maybe confuse you. :rolleyes:
Thanks for the thought Doug
rgb mrgd is off and when I use the alt key it lays down a mask that I can’t zadd
Ctrl is supposed to be for masking…maybe your keyboard or hot key settings are wrong? Link to docs below.
