All element can be deattach from menu and can move freely…
But some important button locked from movement, for example in tools>morphing and masking.
Its possible to unlock it for move to the working area.
Any interface element that exists when ZBrush is launched can be moved onto the shelves or floating palette. All other interface elements (such as the one you listed) cannot. This is because they quite literally do not exist when ZBrush launches, and so would drive the computer schizo or something if they were able to be added to the shelves.
“Ok, I’m supposed to load this button here. Wait! What button? Where is it? Oh dear…”
Its can be fixed by using scripts (doing link or send command to execute command with this buttons)?
Its offen used stuff, and realy not comfortable finding it in menu anytime…
Why not assign hotkeys to them with the Hotkey Editor plugin? Ive done this for
Accurate Curve Mode, which is not there until a tool
s been placed in edit mode.
R
Yes, once you’ve assigned a ‘Custom Hotkey’ using the Hotkey Editor you can drag the custom hotkey button from the ZPlugin>Custom Hotkey menu on to your interface. Save the configuration and the button will always be there but will only work when the target function is enabled.
Great!
Big Thanks!
