Loading 3D models and BIG PROBLEMS!!!
Hello from France!
Excuse me if I make mistakes, my English is very bad, and I sometimes use GOOGLE TRANSLATOR …:o
I have some “old” and “recent” models made with previous versions (ZB2,3, ZB4, ZB5 etc) and now ZB 4R7, and when I load some models (not all) the mesh is black “material” and I can not change it … and when I click on the BPR render, I can see the “real” material …
TOO WEIRD!!! :confused:
On some models there is also a big problem: the vertices goes in every directions, look at the pictures please … Can anyone tell me if he already had these problems and / or an idea how to have a solution please? Thank you
This can happen with ZTLs prior to Zbrush 4R6. If you have 4R6 installed then load them into that and re-save. They should then load all right in 4R7.
Okay Marcus! I will try and I come back to you to tell you if it’s ok! Thanks! :+1:
EDIT: Cool, thank you very much man! ;):+1:
