Little Devil
This work in progress of the cute little devil is based on a sculpture from Mark Newman. I always loved his works and this a kind of a tribute to him :) I will try to stick to the concept but maybe change some tiny things to my personal taste. To create the basemesh, I started with a zsphere model which was used as a template and drawed the topology lines over it. I will post some pictures of the progress later. Latest: [![littledevil_test_post.jpg|450x500](upload://sSuSUMwojwl5GK24KqT0Y4IPO0V.jpeg)](javascript:zb_insimg('118708','littledevil_test_post.jpg',1,0)) [
](http://javascript%3cb%3e%3c/b%3E:zb_insimg%28%27118682%27,%27littledevil_test_post.jpg%27,1,0%29)
Excellent modeling!!! I’m awaiting updates! :+1: :+1: :+1:
Thank you Blade_Rain
some small tweaks and a different shader (thanks Intervain) The material shows the forms a little bit better [![littledevil_04.jpg|600x900](upload://9VA2MuP5TNpgH5ksbKY5RjP5mWy.jpeg)]![littledevil_progress.jpg|809x582](upload://5FFbJKmS07GwlJKYai9n8IV8ZbR.jpeg)
Great design…
and beautiful sculpt … :+1:
Ravishankar
very nice and cute :slight_smile:
Lovely little guy!!
Some asymmetry on the tips of his ears maybe? Otherwise just great :slight_smile:
ivar_sn - Thank you !
Intervain - Thanks for your comment and the material, I really like it :slight_smile:
Atwooki - The next thing I want to do is to retopo the parts which needs more polygons (face,ears, the base of the sculpture). After that I will turn symmetry off and start to refine and make asymmetrical changes. Thanks :slight_smile:
Here is the new base mesh,done with the topology tools. With a better edge flow,which describes the forms better, I can push the polycount to a much higher level. It´s also more usefull for uvmapping and rendering later.
Tomorrow I will start to refine the forms and add more detail.
Great Topology Edit, can you show us your technique in the Finger areas?
Sure, here it is. It´s pretty simple, but should work fine :slight_smile:
[[attach=118392]little_devil_retopo_hand.jpg[/attach]]little_devil_retopo_hand.jpg
Looking very good, Grugi - can’t wait to see this one finished!
As you’re intending UV Mapping him, are you going to fully texture him also?
nice subject and good topo! I´m eager to see your progress on this guy =)
froyd
Atwooki: I´m still not sure if I want to color him, but maybe use a normal map for porelike details, so I don´t have to render millions of polys in max.
Froyd: Thank you. Looking forward to see some new work from you :slight_smile:
So, here is a first small testrender from vray in 3dsmax.
The model is still in progress.I want to change the pose a little bit as it looks too stiff at the moment. Also I want to add much more small details.
More later and I wish you all a Merry Christmas :slight_smile:
[littledevil_test_post.jpg]
Cool character, and great render in the latest image. Happy Holidays.
Very good work! The rendering looks fantastic! Keep it up…
Best regards, Selwy
No less from you my friend! Lovely devil and as always very smart aproach!
I dont forget your 3-4 hours andreseloy tutorial!!!years ago:+1:
The best for you and your family.
Andreseloy
Excellent! Lovely character - He turned out really well :slight_smile:
Have a great Christmas Grugi! and you too andreseloy :wink:
Excelent idea and sculpture! Well done.
Amazing model! I love it! Congratulations
Love the model and the rendering!
You should make some larger images, but I guess it takes a lot if you are using the path tracer.
