It appears invisible in z brush for me, I just put it in the z material folder under zstartup. How would I make it show up and not be invisible?
Ok I figured out I had to load the material, but my god it looks bad. Looks nothing like the preview at the site, am I missing something? Seems like the texture looks fine from the front but on the sides it becomes unfocused and smears out, also seems to have quite a high spec. Looks nothing like limestone.
Some materials only look as they should after a Best render. Note that a Best render is different from a BPR, though you can combine the two by doing a Best render first, immediately following it with a BPR.
