have never messed with the draw perspective…was fun…and learned a couple of things…1.23b
Nice Ron. There seems to be a green mist, just above the lilies, giving the image a brooding aspect. Wether that was a result of painting technique, or planned, well, it works.
It is terrible, i find that that looks like a painting in the watercolour. I find this work really interressante and very beautiful.
nice sensations…
Good work
It has the feeling of a lily pond deep in the woods which you came across unexpectedly. And was overcome with its serenity and beauty. Definitely one of your outstanding landscapes Ron.
Beauty, Ron!
I love how much of the sky you can not only see, but also Imagine from the reflection in the water…Definitely your best landscape SO FAR…
Very pretty Ron! I like the coloring and reflections
No doubt, this is a cool image. What exactly do you mean by “draw perspective”? Is that something I may have missed? Sounds intriguing.
Neat image.
Dave
ok…slosh you are the question man today…giggle…and I will answer the best I can in my redneck way
ok, draw perspective is what I call when you go into draw pallette and then you change the depth and other settings ie width height of your tool you are drawing with…I may have used the wrong terminology, but tha tis what I call it
you can use that with the fiber brush as well…and thank you all so very much for your kind remarks…I love comments truly…as we all do, …I will tell you that this image took all of five minutes to do…but was some kewl results…the water sky reflection is the same reflection used on the Dreamcatcher image…I will try to come up with a script and redo this image or at least the basics…it was all done on one layer too btw…I will start on it shortly…thnx again…and Slosh I will also tell you taht on the dreamcather marbles…all that was used was a simple gradient that I captured with the grabber and used the toy plastic material with the reflection set at 100 turn the texture off after selecting that texture in your materials>modifiers thumbnail image in the bottom left of that panel…it will change the image of your reflection…I use this technique alot…but anyhoo I will post a script shortly…someone may have to alter it but I will try to make it work…
Looks really nice Ron. Like the colors.
here is a script for this…havent run it yet…but the idea is very similar to how I made this one…hope it helps…and thnx for asking how…
RonLIlyPond2.txt
lemme know how it works for ya
Nice landscape Ron. It reminds me of a shady pool in the woods near here which is similarly covered with lily pads. Sadly it’s almot impossible to get to because of the rank undergrowth, so you only get to see it in glimpses between the bushes and trees.
Thanks for the scrip too; I will play that tomorrow.
