Lightbox turning oFF?
Hi
any time when i start zbrush 4 lightbox is appears , and i must go and pick hide , i want to set lightbox to be turn off when i start zbrush
in preferences / lightbox/ open at launch is turnet off , but Lightbox aways appears on startup :frowning:
same problem with the Spotlight , wen i click att to spotlight , lightbox appears again … any time
how i can set lightbox to not appears any time automaticly ?
sorry for my bad English :frowning:
sope this make sens
I don’t think there’s a way to stop Lightbox showing when you start Spotlight. But this post shows how to stop Lightbox showing when ZBrush starts:
http://www.zbrushcentral.com/showpost.php?p=718675&postcount=8
Nope, I tried altering the file - in TextEdit, re-started ZB4… and Lightbox still shows up. It doesn’t pop-up and go, it just stays there, mocking me!
I had created a shortcut (“L” for lightbox,) which does the same think as “n,” but I like “n” for New Document. :+1:
Til’l next upgrade, and beyond!
Hmm, I can confirm that this doesn’t work on a Mac - the DefaultZScript is not run automatically on start up. :frowning:
was just wondering how do I turn off spotlight, I mean I open it up, and I have no idea how to close it. there is no exit button!!
never mind, just find out (>.<)
I can confirm that this works in Windows, however I had to restart ZBrush 4 twice !!!
Closed ZBrush
Changed the Script
Started ZBrush 4, Lightbox appeared - Waited, however after 30 seconds I closed it manually
Closed ZBrush
Restarted ZBrush, Lightbox appeared for a couple of seconds before closing.
Yruyama,
I had the same problem at first. Just press the “z” key (lower case “z”) and it will go away. Press it again to turn it back on. Shift “z” will hide the texture.
Brian Healy,
thanks for the tips it’s even better than just deleting it.
Thanks for the research guys! I’m sure we will find a fix for those Mac users like myself!
Mac - 0, Windows - 1 on this one! :+1:
… working with teh program everyday, its getting annoying that its on at program launch… would love it to go away!
I am on mac…
See this post.
working fine to me
preferences- lightbox - open at launch :o)
The comma key also toggles lightbox on and off.
Anyone found a way to stop lightbox from opening when you enter spotlight ?
