Can I delete Lightbox, Matcap Red without compromising the program.
I have read about config, store, etc, they do not work.
Have spent more time in preferences than I wish to.
Simply put can I delete, dismantel, hide, these two so the subject does not come up again.
Thank you.
Then you’re NOT doing it right…
I posted some files which WILL work.
Appreciate your answer.
Why?
( because they are extremely annoying and of no help to me)
(Pushing it further… they actually discourage me from using the Program.)
Repeating.
I can’t say. They are of no consequence to me. Mine is set to load with SkinShade4. You could save it out of the folder and see if ZBrush starts. Modify and save a copy…I did find this>> http://www.zbrushcentral.com/showthread.php?181661-Accidentally-replaced-and-lost-material-from-the-palette-How-to-reset&p=1051729&viewfull=1#post1051729
Through trial and error have found the answer to my question.
You can’t.
Have to live with these anchors around my neck
