Hey everyone.
Title says it all. I’ll forgo the bitching and moaning and just say that after 23 years I’m finally done with mac. I have lots of questions. First and foremost, recommendations on PC build. Step 1-- the chip.
I’ve done quite a bit of poking around the internet and I’m having a heck of a time getting to the bottom of Zbrush and it’s multi threaded performance. I’ve found a couple of instances of info coming directly from Pixologic that says the more processors the better. In one instance it’s written that you ought to just multiply the number of processors by the clock speed and the the higher the resulting number, the better the cpu. This gives me the impression that active work like sculpting, remeshing, boolean operations etc. would in fact use all cores. Which with my limited understanding of how operations work, sounds kind of unbelievable. Also the other voices advocating for higher clock speed and therefore fewer cores, tend to insist that brushes, sculpting etc ( “active work”) will indeed only use a single core. The voices saying this seem very, very knowledgeable. Is there an answer?
These are the 2 chips I’m trying to decide between:
Intel i9 9900k (8-core, 16-thread 3.6gh/5.0gh Turbo)
AMD Threadripper 2950x (16-core 32-thread 3.5gh/4.4 Boost)
I’m leaning toward the AMD chip as the frequency numbers are really pretty close so single core performance isn’t that far off the i9 while the multi is miles ahead. Also the great and almighty Pavlovich runs a Threadripper (the insane 2990wx 32-core chip), so there’s that.
And just for context. I will be using the machine for mostly sculpting/printing of parts. I want a beast that can devour millions and millions of polys as I sculpt with reckless abandon and zero concern for efficiency in geometry. I’ve been limping along with an age old Macbook Pro. I’m ready to see the light.
I will also be using the machine for C4D (which I know runs better on the i9), octane (which is another discussion entirely), Keyshot, Adobe. These are all second to my Zbrush performance.
Thanks for reading and thanks for any help you can provide!!
