Lazy Mouse
Is it possible to disable Lazy Mouse for all brushes? I use a Surface Pro, so all it does is irritate me when I have to turn it off and then adjust the Z Intensity. I could save out the brush and replace it, but I would rather not do this for every brush.
As far as I know you can’t disable Lazy Mouse globally, only on a per-brush basis, as you mentioned.
Once you’ve deactivated and saved LM for every brush you use, you can backup and restore those brushes into the appropriate folder after a future update, so you’ll only have to save each brush once.
I was afraid of that. Thanks for replying. Peace.
