Layers greyed out and unavailable.
No explanation or errors…My mesh is fine. You can view it here:
http://www.tylersart.com/gallery/personal/frank.jpg
Every normal is correct every vert is welded…etc
Thanks!
Thanks!
I’m sorry, but your question just isn’t clear. You haven’t provided any information about your steps leading up to the problem.
I can say that layers are only available at the subdivision level where the layer was created. If you go to another subdivision level, the layers will be grayed out until you return to the one where they were created.
I imported a brand new OBJ …the one in the image above. Layers are greyed out and unavailable.
Ya follow?
Are there reasons this might happen? Or is it a bug?
also if you change the geometry(not sculpting obviously) in any way you will loose your layers.
Is Tool>Layers>New also grayed out and unavailable? To be able to choose from any of the 3D Layers, you must first create them. Until you’ve created them, the names in the scroll list are just placeholders.
