this has miffed and baffled me for months and since i’m a sucker for pain, i’m only now getting around to inquiring!
why does the record button in the layers palette sometimes (if not always) take several clicks to turn it off??
process:
- import 3 objs
- append them
- create layer for first subtool
- sculpt (only deformations, no rgb or m, no masking either)
- try to turn off layer to toggle and view changes
-first click switches record mode off and then right back on. also, Colorize is now enabled!! O_o
-i’ve wondered if this is a result of using a brush that has rgb enabled by default and even though colorize isn’t enabled, the tool or layer somehow still takes in rgb info - click record SEVEN MORE TIMES and it finally turns off
-now i’m able to toggle visibility - turn back on record and start sculpting again
this behavior, or some variation of it, happens regularly. is this expected behavior? could it be happening as a result of layers storing depth, color and masking info now?
looking forward to any experience users have had w/ this and also feedback from the fine folks at Pixologic.
thanks!
ryan
