one of the strongest Nyi Blorong army.
Damn!! Awesome
Great clothe fabric, can you share your process ?
hello ,I usually use Marvelous for clothing simulation, but not for this one.
everything starts from the sphere that I formed manually from the brush tools in zbrush , because I actually wanted an unnatural effect for the shape of the coat , and use a lot of snake hook brushes to make the tails , because also see from several references.
after that, the coat, I unwrap the UV one by one, then I surface it with fabric alpha.
thank you
Thank you for your answer.
