Kitco Plugin
Is anyone else having an issue installing the Kitco plugin? Once installed I get errors when trying to use it, the first, Script: KitCoMetalQuotes_2019.txt unrecognized command, and if I press it again it says my current subtool is not watertight which it is. I’ve tried many different models with no luck. Any ideas?
Brian
@Piggyson
@brian33433 Can you submit a support ticket to https://support.pixologic.com/
Thanks =)
-Joseph
