This is my CG work named “ King”,The concept comes from the oil painting 《Vajk megkeresztelése》 é se of the outstanding figure of Hungarian academic history painting in the 19th century
As to the model, it is nearly completed in Zbrush, after use the function Sculptrispro sketch of the model,then use Zremesher2.0 recount the surface of the model, adjust by Zmodeler ,then subdivision and sculpt the details .
MarvelousDesigner to calculating the cloth,then sculpt in zbrush。
Demonstrate UV by using plugin Bridge Rizom UV Zbrush . Zbrush export Normalmap
and Displacementmap ,texture painted in SubstancePainter .
The detail of face using the XYZ Texture by Mari and Zbrush plugin :Zwrap.
and rendering is completed in the Arnold of MAYA .
Post production in Photoshop .
I also used NPR of Zbrush to export some images with the special style.
In the following, I make a breakdown to illustrate the process of my work of some local part.
Finally, thanks for ZBC to provide this platform for study and exchange,thanks to my friends who was help me and support on me ,really thanks to the guidance of the Teacher Yang Guang on me.
