Please see screenshot. … what is correct now? Why should I buy the Pro-version if it is the same as the HD-version? Only costs more so it seems.
Please fix the info. Until then I won’t buy, if I risk to get another HD-version without render-passes.
Thanks.
Image attachment does not work (no info, why), linking to image-hosts does not work. Come on! small_orange_diamond
1) As stated in the initial post, the difference between HD and Pro is shown here: https://www.keyshot.com/downloads/documents/comparison/KeyShot6_Comparison.pdf
- Did you click the link that you got when you tried to use a linked image? That tells how to upload images to ZBC. http://www.zbrushcentral.com/showthread.php?161045-How-to-Post-Images-at-ZBrushCentral
Thanks.ZBRUSH_HD_PRO.jpg (0 Bytes)ZBRUSH_HD_PRO.jpg (0 Bytes)ZBRUSH_HD_PRO.jpg (0 Bytes)ZBRUSH_HD_PRO.jpg (0 Bytes)zbrush_hd_prospu09.jpg (0 Bytes)
