Hi there,
I often have some special brush settings, which are not default:
for example: smooth brush no RGB, and Z not 100 but more like 10 (for not to destroy my detail work immediately)
and so on…
But after each restart of ZBrush all settings are gone.
Is there a way (or a plugin or whatever) that these values were remembered?
OR
Somewhere I read, you could clone all your brushes, when you want different preferences.
Is that the right way to clone the whole library? (I can’t imagine)
OR
Can I overwrite somehow the default preferences of brushes, to save them so?
OR
can I use a script to change all individual brush settings everytime at startup?
(it’s not possible to change the smooth brush with a macro script, because it is never loaded as brush, it only becomes active when shift is pressed)
Many thanks in advance
