I was wondering if there is a brush setting that would remove jagged edges caused by some of the chisel brushes. These jaggies seem to be caused by moving the brush too fast at times but that is hard to avoid . If this was Photoshop I would simply increase the brushes sample rate, but that has no effect in Z Brush. Maybe some other setting I am missing ? Thanks in advance. The subtool is a high resolution dynamesh, so that is not causing the jaggies which only occur in part of the brush stroke.
