Dear ZBC support, I am having issues with the Move brush. After moving a section of a sphere the result is not smooth. I have included some photos . Please help! Thank you.
Hello @Raffiderga!
Just to be clear, this isn’t Pixologic Support. This is a community forum.
When you make major changes to a mesh like that, some polygons can become stretched and begin to distort the surface of the mesh. Turn on Polyframe mode (shift + F) to see what your topology is doing.
Two useful tools are:
Dynamesh, which will let you quickly redistribute your polygons across the surface of your mesh to keep them from becoming stretched.
Sculptris Pro mode, which can be used with some brushes to add and remove geometry in real time as you sculpt.
I’m also going to guess that maybe your focal shift slider is set to a low value ? If so, setting this to a higher value for the move brush will produce a softer, less abrupt change in the mesh and may reduce stretching a bit.
Hi Spyndel, I think the Focal Shift resolved the issue. Thank you so much for your help. Much appreciated.
