Hello,
Every once in a while I will have a subtool that I unable to frame or rotate properly. With the framing issue, it sometimes doesn’t center the object to the document, rather it frames it off center, sometimes so much that it’s no longer visible. With the rotation issue, sometimes as I rotate around the object it will zoom in and out, sometimes to such a large degree that my object becomes tiny and I have to manually zoom in again.
Does anyone have any idea why this happens? Sometimes I am able to fix this issue by exporting the object and then reimporting it, but as far as I can remember this doesn’t fix it all the time (I might be mistaken with this though, this issue happens pretty infrequently), and ideally I’d be able to avoid this issue to begin with by knowing what causes it in the first place.
I’ve made short little video that demonstrates the issue I’m having, any help with this would be greatly appreciated. Thanks!
