Is there any way to save a custom brush along with a specific color
I would like to save a few custom brushes on my UI that have a specific colof assigned to them. So for example I would have three brush icons on my UI and when I click on them the color would change to what I had saved with the brush as I click on each brush.
Thanks
Not directly via the global color selector as far as I’m aware, at least not without some sort of scripting, which I can’t help you with. However, you can save a simple color texture with a brush that should load with it and paint in that color as long as the MRGB or RGB channels are active.
Remember that custom brushes will not load with a custom interface until manually loaded into the session, unless they are added to the startup items, which is something you should do sparingly. You should rely on Lightbox for more situational items that you aren’t going to be using every session.
Whenever I’m working on a project with a deliberate palette, I just save a “palette” object painted with all the colors I want to use, and I can sample freely from that at any time.
Another sugestion might be to use the Zcolor Plugin to save color swatches of your own choosing.
Good call, @boozy_floozie !
Thanks guys, got it working!
