Is there a way to snap to quarterview with just shift + mouse movement?
Currently I basically have to go to the 3D head model in the top right to get to a perfect quarterview and it slows down when I create a full turnaround layout for my freelance clients. It’s just a small thing but I was wondering if there was a way to do it quickly without using the head model to turn it? A way to snap the views at every 45 degrees instead of 90? Thanks in advance!
Check out Transform : Axis Rotation which was added recently I think. Set the rotation value and use the <> buttons to step through rotation. Add them to your custom UI for ease of use. hth.
Thanks! This is a good enough workaround for now, much appreicated
