Is there a way to give a gap between IMM curve meetup point? (when pressing shift)
So you know when we press shift while using a IMM curve brush it will close off right?
So i want to make a belt. But the first and third polygroup keeps hitting altogether.
https://www.3dartistonline.com/news/2014/03/how-to-quickly-create-straps-belts-and-chains-in-zbrush/
that tutorial is my base, the thing is, i have to use the second method with the second polygroup being smaller, cuz if not my brush will become so small and hard to control. So is there a way to control the meetup point?
“…polygroup keeps hitting altogether.”
I don’t understand what your problem is
basically i want to make a belt. I already download some from badking and from the zbc forum, but it keeps intersecting when i tried pressing shift to close the curves.
Do you know any way to create a belt closing correctly?
