I’m wondering if there is a way to do a perfectly even stroke around the edge of a poly group using a normal brush. I know I can use ctrl+shift to run a curve brush around an edge, and although they work very differently, I’m wondering if I can do something similar with a normal brush? Or if there is another other different way to do the same thing using a normal brush?
Directly, I’m using a brush that looks like a sewing seam, and want to run it around the hem of a t-shirt sleeve for example and have it an even distance from the sleeves end all the way around. I can sculpt it in with lazy mouse etc, but it’s hard to keep even and I’ve got a lot of these hem areas do to so am wondering if I can automate part of the process.
