Need a way to create an exact replica of the image below (obj) but mirrored but not messing with the how the obj is wound or ordered? It’s a morph target I’m trying to figure out how to do but all my attempts in other programs and scripts turned up less than satisfactory results.
Example using on script it mirrored it but left the left side there too so it just created a mess when the morph was dialed up.
Another example, coming from ZBrush itself using the Mirror option under the Deformation panel did mirror it to the other side but in the program I’m using the morph the morph basically reversed everything so the pentacle and necklace chain ended up inside out and morphed DOWNwards rather than up and to the side. Not what I’m after.
Any luck making this happen within ZBrush?
Thanks so much!
