Is there a way of mark rotation in Y axis as default?
Sry if this question is maybe too simple but, since i only sculpt using Y rotation it buggs me that i have to select the option each time I open Zbrush, is there a way to keep it as default?
You can record a Macro and have it run automatically at startup. See my post here on how to do it.
You can also download Joseph Drust’s Startup Master from the pixologic download center
http://pixologic.com/zbrush/downloadcenter/zplugins/
http://pixologic01.com/zplugins/ZStartupMaster_v5.1_Install.zip
It has an option to set rotate y as the default among other useful startup settings.
Thank u so much, ill give it a try asap
