Is there a folder in ZB. where tools can be added to the append pop up window
From the sub tool palette when using the append button you get a pop up window containing zbrush primitives.
Is there a way to add other tools here?
Thanks
That popup shows the 3D tools in the Tool palette, so all you need to do is load or import what you want and it will appear. You can use the Copy Tool and Paste Tool buttons at the top of the Tool palette to copy a model (with all its subtools) from one project to another.
(Make sure you select a primitive you don’t need as pasting will replace it.)
Thanks Marcus, but can you please explain the above, I don’t quite get that.
Actually I made a mistake and you don’t need to worry. Just select any of the 3D tools in the Tool palette and press “Paste Tool”. The tool you select won’t be overwritten. The tool you paste will simply be added to the Tool palette. (It will be the selected tool after pasting which is what confused me.)
