There a dozen of brush that does highlighting in zbrush, but how come there are non that does colour burn like in PS? I have tried various highting/intensity brush with + alt alternatives, but all ended up with black stroke appearance, without taking colour in consideration. is there should be a solution without ending going back to photoshop?
without having it in front of me to double check i think if you hold the alt button down on some of those brushes you can add color to the mix…am not sure if that works for all the brushes like the ones you mentioned but it’s quick to try it out.
Yup select highlighter & hold down ALT…
I know you can hold alt, but by defualt it wont give you good burn, its a very black result with no colour, I have to select “Main” in modify and use a complement colour to the colour I wish to burn, although this gives you flexability so you can alter the colour shift as you burn, but its really odd way of doing it.
