Is it possible to project only 'parts' of a subtool to another subtool?
Perhaps I’m not doing it correctly but I was wondering if its possible to project only certain parts of a subtool onto another similar subtool without any details? I would assume one could just mask the areas of the detailed subtool that I want projected onto the other subtool before projecting but that doesn’t seem to be working… Is there another way to do it?
Just for further explanation… I have a base .obj jewelry ring that I imported to Zbrush and textured. Now I have a similar .obj base ring with slight sections mission/altered/cut out. I want to project only certain details of the first ring I detailed on zbrush onto this new base .obj ring.
Either delete/hide the unwanted sections of the detail subtool, or mask the parts of receiving subtool that should take on any detail.
thank you for the methods… It will come in handy … I figured out how to use polygroups which should work also
