Is it able to loop through all layers while one layer is recording?
I’m using zscript to loop through all layers and switching visibliity, but when there’s a layer recording, then select up / down won’t work, so I must turn off the recording stat.
Then I found that if the recording layer isn’t shown in the list, then ICLICK and IModGet will show error message: Interface item does not have special modifier.
What can I do?
Nope you can’t as once you select another layer the recording mode will be stopped.
Hope it helps,
Nicolas
