Intuos 4 config
I’ve just received my new Intuos4 S.
Anyway i really wanna use the new touch wheel for Draw Size, Z Intensity and Focal Shift.
But i can’t seem to figure out a way to configure the software.
Is it even possible? it just seems like a natural way to configure the Intuos4 touch wheel to really get the most of it…
If there is any other suggestions they are more than welcome
Thanks
bump,
doesn’t anyone have an intous4 with this proposed setup??
I’ve set draw size to the wheel-thingy by assigning the bracket keys (same keys as photoshop for brush size). You can also set zoom (but not scale) to the wheel (bracket keys combined with the numpad plus and minus keys).
Since a single shortcut brings up a slider in zbrush for focal shift (o),rbg (i) and z intensity (u), I set these shortcuts to the top buttons on my Intuos 4.
I’m assuming that any functions you assign to the wheel have to have seperate keys to"increase/decrease" the function. Intensity, rgb and focal shift don’t work that way in Zbrush.
Maybe someone will jump in and correct me if I’m wrong about this.
Yeah I’m looking for help with this also.
Setting up Zbrush 4 with the intous 4.
-peace
Hi, and thanks for the help, i reassigned the hotkeys for the draw size increment and it’s now working as i want it to…
but as you say, z intensity, focal shift, rgb intensity doesn’t have that kind of shortcuts available
But that shouldn’t be a problem should it? i know the draw size is a script, but could i be altered to include the others as well??
